Bavaria 38 ocean shower
Author Topic: Bavaria 38 ocean shower  (Read 3962 times)
Jam
« on: May 04 2018, 22:49 »
Boat just in water and turned on water pump and found shower is leaking.  Looks like ice has cracked the main body underneath, never thought to drain it or open taps so water in body cracked the metal.  Is this just a standard shower thermostatic shower that I could buy from plumbers merchant or is there anythind I am missing.
John
patprice
Re: Bavaria 38 ocean shower
« Reply #1 on: May 04 2018, 23:44 »
For my B42 cruiser I have used hardware store available replacements in Greece.
« Reply #2 on: May 05 2018, 05:00 »
John
It looks to me that your system has already been modified with an addition from your local plumbers merchant as all other Bavaria’s of that age that I’ve seen so far, had a tap system that incorporated a shower hose that could be tucked away inside the tap fitting, and didn’t have the rather more sophisticated thermostatic control that you have.
Fenders
« Reply #3 on: May 05 2018, 08:19 »
In the past I have found Penguin Engineering very helpful particularly for obscure items. They are on Hayling Island.
Check out their website.
« Reply #4 on: May 05 2018, 08:26 »
All the ocean range [centre cockpit ] have thermostatic  showers. They are standard plumbers merchant items.  Geoff
Jam
« Reply #5 on: May 05 2018, 10:59 »
Thanks for all replies, as always appreciated
John
