Wet cockpit lockers on Bavaria 38 Ocean 2000
Author Topic: Wet cockpit lockers on Bavaria 38 Ocean 2000  (Read 3681 times)
heywoodp
  • Bavaria 38 Ocean 2000
  • Boat Model: Bavaria Ocean 38
« on: April 18 2018, 20:30 »
After returning to the boat, stored on the hard in Corfu, the rear lockers have about 6 inchs of water in them. The seal on the lid seems ok. Can only put it down to excessive water in the drain channel during the winter rains. Anybody else had this problem and how did you cure it ?
Re: Wet cockpit lockers on Bavaria 38 Ocean 2000
« Reply #1 on: April 19 2018, 11:02 »
Had that on our 40 Ocean. It actually came from two places. One was aft and the water came in at one of those deck holes left from when the teak was installed. Did the same treatment as for the rest, cut out the failing short piece of caulking, drill the hole to get a clean edge, fill with epoxy, then re-caulk the deck.
That didn't stop it all though, and after much poking around with the USB inspection cam on a rainy day, I eventually traced the remaining water ingress to the U-bolts installed just forward of the lazarette lids, which originally were attachment points for the jacklines. Those turned out to be leaking on both sides, and getting to the nuts on the inside was an absolute horror - both required cutting access holes into the GRP ceiling liner in the aft cabin and one was even glassed over and right above the bulkhead, which luckily was very rot resistant.
heywoodp
« Reply #2 on: April 19 2018, 16:33 »
Thanks Yngmar, I hadn't thought of the ubolts leaking. Something to look at with a little water spayed on it.
« Reply #3 on: April 19 2018, 21:45 »
..............I hadn't thought of the ubolts leaking. Something to look at.............
And any other penetrations to the structure in area of the cockpit lockers,  pushpit rails, toerail fastenings, turning block bolts, if it goes through the grp then it can be a potential leak.
