Interior door
Author Topic: Interior door  (Read 6602 times)
Harrydog12
Interior door
« on: October 03 2012, 17:10 »
Could anyone advise me where I can purchase a new door for the heads please?We have been using the shower quite a lot during our 6 months sailing in the IONION and it as softened up at the base
Re: Interior door
« Reply #1 on: October 04 2012, 22:45 »
Had the same problem (very common). Not sure if Bavaria still supply spare doors. Ours was repaired very skilfully by cutting off the lower 50cm or so of the panel and gluing a new piece on. Not a perfect match but looks OK and has stood up to now 7 years use. To avoid, always ensure the door and frame is wiped dry after using the shower.
Plupp II
  • Boat Model: B47
Re: Interior door
« Reply #2 on: August 08 2014, 14:13 »
Do anyone know where to buy new doors to heads (WC) for model B47 cruiser 2001?
Plupp II
Re: Interior door
« Reply #3 on: August 17 2014, 07:24 »
I've got the same problem, but I think it's just the veneer lifting. I plan to fix it with some PVA glue and a hot iron.
Re: Interior door
« Reply #4 on: August 24 2014, 14:07 »
How about prevention. Is there an issue with the grade of finish used on the door? One would expect for a wet area, that the finish should be waterproof. Is it worthwhile resealing or applying a coat of sealant on to teh door?
Kasella
  • Boat Model: Bavaria'06.50'
Re: Interior door
« Reply #5 on: August 28 2014, 02:39 »
Hi Guys
Ive had a similar issue, i took my two head doors to a local joiner / cabnet maker and they sanded off the original veneer then replaced it, stained it, then applied five coats of Mirrortone two pack urethane at 75% sheen level and i tell you and iam fussy i cant pick the difference from one side to the other and surrounding woodwork. Im very very very happy, cost me just on AUS$1200.00 way cheaper than new doors.
Cheers :)) :tbu
Re: Interior door
« Reply #6 on: September 09 2014, 10:21 »
I have fitted a plastic track with a curtain that covers the door, no water gets on the wood, use shower all the time in Biscay, hope this helps.
Bav 38
