Sail Drive gator
Author Topic: Sail Drive gator  (Read 4095 times)
Kibo
  • Boat Model: Vision 46
Sail Drive gator
« on: April 13 2018, 22:51 »
Hauled out after the winter season in the Caribbean earlier this week and for the second year running my saildrive rubber gator or diaphragm has detached itself from the hull.
Last season it was completely gone, this year it is hanging on by one side.
I talked with my yard maintenance guys and they are planning on re-glueing this but I wonder if anyone has any recommendations on how to do a more permanent fix on this. Specific adhesive recommendations perhaps?
I heard that some people have made a GRP rigid moulded cover and then semi-permanently bonded this to the hull. Anyone know about thsi approach? Pros and Cons?
Any experiences appreciated.
Ian
The Other Woman
Re: Sail Drive gator
« Reply #1 on: April 14 2018, 07:26 »
Same happened to me so after re-glueing i put some self  tapped through the rubber with large washers on it is safe to do as there is a large flange (sholder). It's been on for two seasons.
Will take photo later and list.
Good luck.
Mick
« Reply #2 on: April 14 2018, 07:44 »
Mine came off the first season after launching the boat from new. I attached the replacement with Hypalon which is used to repair the tubes of inflatables. It is still in place 11 years later  ;D :kewl
« Reply #3 on: April 14 2018, 09:40 »
Adhesive sealant (Sikaflex 291i or equivalent), after sanding both hull and rubber and rubbing clean with acetone. The trick is to squeeze out the sealant and then make a nice bevel, so the flowing water can't get in there to pry it off. I've also partially coppercoated over it, but doubt that makes a big difference.
Ours is holding strong and we've bashed the boat through some rough seas the last year.
The Other Woman
« Reply #4 on: April 14 2018, 11:56 »
There you go
Kibo
« Reply #5 on: April 14 2018, 14:27 »
Many thanks everyone.
Good options and happy to see you have overcome the annual cycle of glue/reglue
Hopefully I can join you in gator longevity now !
Safe sailing everyone
Ian
Neil
« Reply #6 on: April 18 2018, 10:52 »
Sikaflex 291i worked for me.
