Bavaria 36 2003 Centre cleat
Author Topic: Bavaria 36 2003 Centre cleat  (Read 3449 times)
stewartv
« on: April 05 2018, 18:28 »
My 2003 Bavaria 36 has a sort of moulding on each side where a centre cleat could be installed.  Does anyone know how hard / easy it is to fit these?  I heard that the clutches on the cabin roof have a metal plate pre-installed under the fibreglass so you can drill and tap if you need to install additional units. Would the clever Germans have done the same with the centre cleats by chance?
artemis
Re: Bavaria 36 2003 Centre cleat
« Reply #1 on: April 05 2018, 20:57 »
Hi There
I would assume so if you take off the wooden skirt inside and look up you should see the metal plate inside or at least you can on my Bavaria 34 year 2001. I have cleats in both side midships
Rgds
Mike
Artemis
amikeren
  • Boat Model: bavaria 44
« Reply #2 on: April 06 2018, 14:34 »
I have done this before 5 years on a bavaria 36 2004
the place is prepared for the installation
Ami
The Other Woman
« Reply #3 on: April 06 2018, 16:05 »
Hi all
Yes it's an easy job, with easy access from below.
Mick
stewartv
« Reply #4 on: April 07 2018, 14:41 »
Thank you very much for your responses, I'll have a closer look next time I'm aboard.
