Anchor wash down pump recommendations ?
Author Topic: Anchor wash down pump recommendations ?  (Read 10285 times)
Stuart
« on: September 16 2012, 17:55 »
Hi All
Our pump died last year and I was wondering if anyone could suggest a good powerful, reliable pump that wont break the bank.
Stuart
Sweet As
Re: Anchor wash down pump recommendations ?
« Reply #1 on: September 17 2012, 09:20 »
Hi Stuart,
I'm not able to advise on your pump question, but I am interested to learn more about your anchor wash down arrangement. I have been considering adding a system to our Bav 36, but am reluctant to drill another hole through the hull to source water or to run a hose all the way back to the nearest seacock in the head beside the companion way. Where does your system source the water from?
John
Sweet As
Bav 36
Stuart
« Reply #2 on: September 17 2012, 18:36 »
Hi John
I was able to "T" off the raw water inlet for the toilet just aft of our "V" berth (we have a Bavaria 42) so not a very long run to the pump which sits under our berth.
I know what you mean by not wanting to drill another hole in your boat, I just installed a watermaker over a year ago and drilling that hole for the thruhull  had to be the hardest part of the whole install.  :))
Stuart
MIA
« Reply #3 on: October 13 2012, 13:36 »
Stuart
Where did you install the outlet for the spray
Stevie
Stuart
« Reply #4 on: October 13 2012, 16:15 »
Stuart
Stevie
Hi Steve
I routed it into the anchor locker port side, aft (the vertical face of the base for the windlass). I was able to remove the bulkhead panel at the foot of the "V" birth and that made it so much easier.
here is a link to some of the mods we've done showing the "V" birth access.
 http://www.bavariayachtowners.org/page8/page6/page6.html
Stuart
MIA
« Reply #5 on: October 14 2012, 04:25 »
Stuart
Are you spraying the water onto the chain as it comes through below the windlass and into the anchor locker to drain out the bottom
Stevie
Stuart
« Reply #6 on: October 14 2012, 06:22 »
Stuart
Stevie
Hi Stevie
No Im trying to get the guck off before it comes over the roller, doesn't always work out ;)
Stuart
MIA
« Reply #7 on: October 14 2012, 06:35 »
Stuart
Thats what I was thinking, so where does the spray actually come out, did you drill a hole on the bow under the anchor roller
Stevie
Stuart
« Reply #8 on: October 14 2012, 16:55 »
Stuart
Stevie
Hi Stevie
Sorry I didn't explain properly, the pump outlet is inside the anchor locker, near the windlass, with a short length of garden hose and a adjustable spray nozzle. This is handy cleaning off the foredeck if any mud/whatever gets on there and reaching over the bow to clean off the chain and anchor when it comes on board
Stuart
MIA
« Reply #9 on: October 15 2012, 03:44 »
Stuart
Got the idea know thanks
Stevie
