D2-55B Temperature sender screw thread
Author Topic: D2-55B Temperature sender screw thread  (Read 4506 times)
buttonfreebie
  • Boat Model: Bavaria 41
« on: December 23 2017, 16:23 »
Does anyone know the thread of the temperature sender. I only have the alarm panel without gauges and want to fit gauges and new dual senders. The oil sender I am fairly confident is 1/8 th NPT and think the temperature sender is 5/8th but not certain.
PEA-JAY
  • Boat Model: B-Cruiser 39
Re: D2-55B Temperature sender screw thread
« Reply #1 on: December 25 2017, 09:18 »
I installed a VDO water temperature 50mm instrument and it shares the existing water remprature alarm sender unit. Both work perfectly on my D2.55C
Raph.
buttonfreebie
« Reply #2 on: December 26 2017, 20:52 »
My engine is the D2-55B and I suspect the sender only has an alarm contact. Can anyone confirm please
Graham
« Reply #3 on: December 27 2017, 06:47 »
Your original temperature alarm sender should be in a pocket such that you can take it out of the pocket without losing any cooling water. Suggest you take it to your nearest motor factor store, and ask one of the assistants there if they can identify or just simply match it to a new sender unit that will work with your temperature gauge.
Even if it's not in a pocket, the amount of cooling water you'd lose is no big deal so long as you are not motoring anywhere, just top it up after the fitting has been replaced.
« Reply #4 on: December 27 2017, 08:36 »
On my md22l I have installed a simple water flow sensor in the raw water line after the pump to warn of blockage or muppet me failing to turn on the water . Very cheap to buy [RS components ] and easy to fit . Geoff
« Reply #5 on: December 27 2017, 12:47 »
Hi Geoff
That's a good idea, which one did you use? I've looked at the RS site and there's hundreds!
« Reply #6 on: December 27 2017, 13:19 »
Hi Mark, I will have a look on the site and try to let you know ,failing that I will be down at the boat on Thursday and will get the gen off the unit.  Geoff
PEA-JAY
« Reply #7 on: December 27 2017, 17:22 »
Sorry, perhaps I wasn't clear. If installing a water temperature gauge You do not need a new water sender unit if you opt to install a VDO gauge. The existing sender unit will suffice.  All you have to do is to fit a second electric cable (I placed the joint inside the black box) and take it directly to the VDO gauge. I have tried this and it's been working for two seasons without fault. When you add an oil pressure gauge then yes you need to replace the sender unit with one that Has two contacts. The new sender unit and the gauge need to be calibrated identically, best scale is 0 - 5 bar. See images. I hope this helps!
Raph
buttonfreebie
« Reply #8 on: December 27 2017, 17:41 »
Hi Raph
Thanks for further info and the photos.  I will check it out before buying a new temp sender. I plan to install the gauges as you have as I have the same panel arrangement  Did you use a hole saw for the Gauge cut outs
Graham
PEA-JAY
« Reply #9 on: December 27 2017, 19:32 »
I did, but remember you're cutting into thin plastic, so it's risky. The heat might melt the panel and you will end up with a hole much larger than you wish! If you're unsure better go with chain holes and a file.
« Reply #10 on: December 28 2017, 16:27 »
Mark , the unit is RS 257-082 .  it is shown on the site ,same as mine but twice the price ,still I bought mine about 15years ago. Geoff
