Anchor Light Not Working
Author Topic: Anchor Light Not Working  (Read 6318 times)
Tethys
« on: September 11 2012, 11:05 »
The anchor light on our 2003 B36 has stopped working.  It is not the LED (replaced with a filament bulb & a new LED to test) so presumably a connection somewhere.  I've had a rummage above the removable panel in the saloon at the mast and can find no joins there - have I just not found them or are there really no joins / connectors there meaning if ever the mast had to be unstepped all the wires would just have to be cut and subsequently re-joined?
If there are no joins there then I suspect connectors on the masthead light unit itself.  The tricolour is still working.
Any similar experiences?
Thanks,
Andy
Re: Anchor Light Not Working
« Reply #1 on: September 11 2012, 11:54 »
If there are no joins there then I suspect connectors on the masthead light unit itself...
Only way to find out is to go up with a meter and test at the bottom of the connector. Also test if you can get it working with a wire connected to negative and then positive.
Note that is this is the LED, they may need to go a certain way around.
Tethys
« Reply #2 on: September 11 2012, 16:48 »
Yep that's probably the only way, unless anyone knows for sure if there is usually a join lower down that I can look for & test first!  The LEDs I have are not polarity conscious, so it's not that!
« Reply #3 on: September 13 2012, 23:08 »
There is a connector under that panel. Pull the wires down and you should find a heavy duty choc block - at least there is on my 37.
Tethys
« Reply #4 on: September 14 2012, 19:28 »
Thanks for that, I'll have another look.
