Raymarine Navstar 120 problems.
Author Topic: Raymarine Navstar 120 problems.  (Read 4026 times)
Clivert
« on: September 24 2017, 09:38 »
My plotters were taking ages to find a fix and I found out the 120 has a lithium battery to maintain a memory.
Many posts suggest the battery,being soldered in, is difficult to replace.
It is but it can be done.
Holding the battery firmly to protect the connections, I gently prised the battery away from the clips using a stanley knife.
The soldered joints are only " tacked " lightly on so come away with gentle persuasion.
To mount the new battery I taped it in place and then inserted a slice of rubber from an eraser above and below to hold it firmly in place.
It means that should I need to replace it again it will be easy.
 I should have taken photos to illustrate it but the word is patience and a gentle but firm touch.
Re: Raymarine Navstar 120 problems.
« Reply #1 on: September 24 2017, 10:26 »
Thanks for the info, Clivert. Very helpful. Welcome to the forum, we hope you'll find it useful.
Re: Raymarine Raystar 120 problems.
« Reply #2 on: September 24 2017, 11:03 »
I believe you mean Raystar 120? You can also fit a coin cell battery holder (pennies from RS components and other electronics suppliers).
Clivert
« Reply #3 on: September 24 2017, 14:47 »
Battery is a cr2032
