Electrical panel warning light
Author Topic: Electrical panel warning light  (Read 3912 times)
ejessen
  • 2001 Bavaria 40AC
  • Boat Model: Bavaria 40AC
« on: July 13 2017, 07:40 »
On my 2001 Bavaria 40 AC, this warning light came on today - see attachment.
Any idea what that means?
-- Erik
Re: Electrical panel warning light
« Reply #1 on: July 15 2017, 09:20 »
Do not know this panel, but the icon next to it may indicate voltage drop of the battery - does it turn of if you charge the battery?
« Reply #2 on: July 16 2017, 10:57 »
It's fairly easy to follow the wire for that light. I have the same panel, but the light isn't wired to anything, probably due to the shorepower charger having been upgraded in the past. Also the panel has support for two different charger systems from production, so it may be wired differently on different boats. Checking yourself is the best and easiest way to find out.
« Reply #3 on: July 16 2017, 17:59 »
I have a different panel but the same light - it comes on when the battery drops below 10.5v (or might be 10.0v). I noticed it was on when I was in the process of buying the boat and discovered (before purchase!) that the batteries were both completely duff (the leisure batteries, not the starter). Check the voltages of the batteries with a voltmeter, it may be that one of them has failed and is pulling the other one down.
heywoodp
  • Bavaria 38 Ocean 2000
  • Boat Model: Bavaria Ocean 38
« Reply #4 on: July 21 2017, 17:02 »
On my Ocean 38 (2000) it comes on when the mains charger is in 'charge' mode before it switches to 'float' mode. This happens just after you connect shorepower then goes off once the batteries are all charged.
