Good latch for fore peak hatch
Author Topic: Good latch for fore peak hatch  (Read 5019 times)
Atlantica
« on: April 11 2017, 13:48 »
I'm planning to make a hatch into the fore peak storage space in my B38. Just as Odysseus has made here:
http://www.bavariayacht.info/forum/index.php/topic,135.msg625.html#msg625
But how about suitable latch to lock and tighten the hatch? I want the hatch to be removable without any hinges. Any suggestion for suitable and cheaper solution than Bavaria's original (but very good) latches? This is quite expensive for such a simple job. Especially if you want to buy two pcs.: https://www.svb24.com/en/bavaria-sliding-bolt.html
Or does anyone know any other places to purchase Bavaria's originals?
Re: Good latch for fore peak hatch
« Reply #1 on: April 11 2017, 16:06 »
The Bavaria latches are very good, but that's silly money!  How about these from SeaScrew?
https://www.seascrew.com/browse.cfm?THUMB-TURN-LATCH---GARDEN-SHED-TYPE--BUT-STAINLESS---PLASTIC&p=0000001332
« Reply #2 on: April 11 2017, 16:53 »
What sort of cutter are you planning to use? Cannot get up the courage to cut one myself.
Atlantica
« Reply #3 on: April 11 2017, 21:54 »
Thanks tiger79! I need to check that type of latch.
I'm going to start cutting with electric multi tool and continue with jigsaw. I will test first into something similar to find the best possible blades. And masking tape will be used for prevent ripping the front surface.
« Reply #4 on: April 12 2017, 06:31 »
I'd use a fine tooth blade in the jig saw to prevent splintering on the face of the wood, and keep the speed of the saw low to avoid over heating the blade. Using wide masking tape on the wood to draw out where you intend to cut will enable the cutting line to be seen more easily and help to prevent the sole of the jigsaw from marking the surrounding wood.
