New Cruiser 33 control panel not showing starter battery voltage
Author Topic: New Cruiser 33 control panel not showing starter battery voltage  (Read 5152 times)
ANTREVELL
My 2013 Cruiser 33 . The 301 control panel shows the percentage full of water and waste tank.
It also shows the domestic battery voltage  but when I select starter battery voltage it shows nothing .
Before I start looking for a problem . I wonder if the starter battery is maybe  not connected to the panel. I would appreciate anyone with the same boat and panel could check there's
Regards Tony Revell    Pegatha
Just a thought, is the starter battery isolator switch turned on?
ANTREVELL
Very good point . I will check . Will feel an idiot if that is the problem.
Regards Tony
Just checked mine - reads fine with the starter battery switched on.
ANTREVELL
Hi Symphony
I have not been back to my boat to check. But if your engine switch is off do you still get a reading .
Regards Tony
Ziffius
Generally if the battery is isolated you won't have a reading on the voltmeter
Think the panel is powered from the house bank as nothing goes on until that is switched on. will try all combinations when I go to the boat tomorrow.
I've just checked on my boat.  With the starter battery turned off, the panel reads 0 volts.
Ripster
Same on my 36 (2011) with starter batt isolator off 0 volts are shown on the panel.
GeoffV
  • Boat Model: Bav 37 Cruiser
  • Boat Year: 2016
Same on the cruiser 37.
ANTREVELL
Hi All
I am delighted but very embarrassed that with the engine switch on the panel shows starter battery voltage . I had assumed it would be like the Nasa battery monitor and be connected directly to the battery. So thankyou Tiger for suggesting this . I will creep away and hang my head . But I am delighted I have not got a problem
Thanks to everyone it is nice to have all the support .It is a shame we cannot all meet up but that would be a lot of sailing !
Regards a relieved Tony   Cruiser 33 Pegatha
Result!  And, don't worry, we're all happy to help and we've all got much worse blunders to confess!
... we're all happy to help and we've all got much worse blunders to confess...!
+1! Amen to that, Tiger.
Glad you're sorted, Tony. This is such a good forum - a huge fund of experience and technical knowledge.
