Bavaria Ocean window leaks
Author Topic: Bavaria Ocean window leaks  (Read 6995 times)
MikeGowland
« on: August 05 2012, 19:19 »
Has anyone stripped the windows down and re- seated them? If so is there a seal that needs to be replaced or do you mastic them back in?
njsail
Re: Bavaria Ocean window leaks
« Reply #1 on: August 09 2012, 00:54 »
Hi Mike - are you talking about a leak in the metal port frame or the acrylic window/rubber seal?  Then again the port a Rutgerson or Lewmar?
MikeGowland
« Reply #2 on: August 09 2012, 18:25 »
The metal frame as I'm getting water in a locker in the main cabin and the only place I can think of that's leaking. Since tightening the small screws the leak has diminished but not stopped. I think they are Lewmar.
Hope this helps
Mike
njsail
« Reply #3 on: August 10 2012, 02:12 »
Here are two lewmar links from another thread on this forum.  It's a start.  I have Rutgerson ports on our boats so I can't really comment from experience with the lewmar ports.
http://www.lewmar.com/FAQCategory.asp?Cat=102
http://www.lewmar.com/product-listing.asp?action=search&type=135
