Hatch replacement seals
Author Topic: Hatch replacement seals  (Read 3139 times)
Sen Mora
  • Boat Model: Bavaria 41
« on: February 28 2017, 20:04 »
I know this subject, or better, leaking hatches, was already addressed to some extent.
I have B41 2003 the two main Lewmar hatches are 556 mm square, which seem Bavaria specials ( go figure why they did not use the 60 size which is less than 1in bigger. Must be to be special=more $ ).
The replacement seals are of course very expensive, on top of it lewmar calls them Low profile (25mm). I measured 32mm which is Medium profile. Here are my questions:
   a. Do the MP and LP use the same seals
   b. Did anyone found the manufacturer of these seals to get them by foot at reasonable price
   c. Are the corners vulcanized or just turned around acrylic
Many thanks
Sen Mora
Re: Hatch replacement seals
« Reply #1 on: March 03 2017, 13:15 »
Hi there, I am somewhat surprised that this subject did not generate any interest/reply. Hard to believe I am the only one with this issue. Many thanks for any input.
aquapore
  • Boat Model: bavaria 41
« Reply #2 on: March 05 2017, 03:04 »
Hi Sen -I have the same boat and same problem. I watching for the responses.
Regards
Aquapore
sgparkin
« Reply #3 on: March 05 2017, 14:02 »
When I had to replace my hatch acrylics Aquafax had the rubber seal in 10m lengths to cut yourself (and glue the ends together). part no. 360068999 £31.81+vat.
Or you could try to reuse the old ones if still in good condition.
Bw - Simon
