md22l coolant leak
Author Topic: md22l coolant leak  (Read 2941 times)
md22l coolant leak
« on: January 06 2017, 13:32 »
I have a 2001 B40 ocean with an md22l engine. Recently I have noticed a small freshwater coolant leak into the bilges apparently from the front of the engine. I suspect the freshwater coolant pump shaft seal is showing its age. Any other ideas out there? Geoff
Re: md22l coolant leak
« Reply #1 on: January 06 2017, 14:14 »
I presume you mean a coolant leak, rather than freshwater.
The collant pump is on the front of the engine (behind the cambelt cover) and they are prone to the front seal going, resulting in a slow drip from the pump which runs down the front of the engine and drips into the bilge.
The only solution is to replace the pump.  Unfortunatly pattened are getting scarce now and VP ones are about £300.
