Squeaky Rudder - Video
Author Topic: Squeaky Rudder - Video  (Read 5937 times)
  • Boat Model: Bavaria 37
« on: December 30 2016, 16:03 »
Any thoughts on my suddenly quite squeaky rudder? I have tried putting some oil onto the bearings.
https://www.youtube.com/watch?v=JfpBFA9Jy08
Will
Re: Squeaky Rudder - Video
« Reply #1 on: December 30 2016, 16:35 »
Sounds just like my wheel when the wheel brake tensioner is on, check the stud and the plate is releasing properly you will have to take panel off binicle and look up inside. Use some WD40.
Bav 38
« Reply #2 on: December 30 2016, 22:25 »
Looks like the wheel is warped, could that be due to some sort of recent impact which may have distorted the spindle and hence the squeak?
« Reply #3 on: December 31 2016, 07:58 »
Will
When mine did that oil quietened it down for a while but at the end of that season movement in the rudder showed that the bearing was worn to the point of needing replacement. The bearings should not need oil and instructions supplied with new ones stress that point. The squeaking I had was best heard at the top of the rudder near the locking nut - is yours the same?
« Reply #4 on: December 31 2016, 09:33 »
Will
Yes it sounds as if its coming from the locking nut.
Salty - No impacts
« Reply #5 on: December 31 2016, 11:24 »
Your wheel looks very warped.
Try spraying some ptfe on the bearing behind the wheel and see if that shuts it up.
If it does, then it's the wheel bearing, and if it doesn't then it could be the rudder bearing.
« Reply #6 on: January 02 2017, 16:59 »
Sprayed some GT85 on the nut under the lift up cover - and the noise appears to have gone away!
Will keep an eye on it.
« Reply #7 on: January 02 2017, 21:47 »
With your warped and wonky wheel Willfinch, I'd keep my eye well away from it and leave it to the GT85 to sort out!!
robgs
  • Boat Model: Vision 40
« Reply #8 on: January 02 2017, 22:25 »
The rudder on my 2007 Vision 40 gets squeaky from time to time. In my case it is the load bearing washer just under the locking nut. Sometimes a fresh water rinse works but the best is to use McLube Sailcote, a fast drying teflon spray.
