Zincs for MD22L + 120S-E + folding prop
Author Topic: Zincs for MD22L + 120S-E + folding prop  (Read 5256 times)
ejessen
  • 2001 Bavaria 40AC
  • Boat Model: Bavaria 40AC
« on: December 08 2016, 06:40 »
I have a 2001 Bavaria 2001, with an MD22L engine and 120S-E sail drive.
The previous owner added a folding prop. Added a few pictures the diver gave me here : https://drive.google.com/drive/u/0/folders/0BylZRYeThdS6VXhwdmZ4RGNkYzg
Standard zincs for this drive+ 3 blade folding prop should be : fixed ring 876286, 3 piece split ring 3858399.
Has anyone come across a split ring kit that can be used instead of the fixed ring (876286). Lot of work for the diver to take off the prop every time the zinc needs to be replaced.
-- Erik
Re: Zincs for MD22L + 120S-E + folding prop
« Reply #1 on: December 08 2016, 07:43 »
The topic has been discussed earlier at YBW forum
http://www.ybw.com/forums/showthread.php?337935-Volvo-Penta-120S-saildrive-anode-adaptor
As far as I understood, there is no reasonable alternative to the fixed ring.
How often do you lift the boat to renew antifouling? Would it be a good interval for anode replacement as well? If not, can you extend the anode lifetime by using a hanging anode as suggested in the ybw thread?
BR,
Tommi
Same model, same year, same engine, drive & zinc, but currently overhauled to dock due to the northern Baltic sea freezing over  :(
ejessen
  • 2001 Bavaria 40AC
« Reply #2 on: December 08 2016, 16:36 »
Hi Tommi,
What is the brand/model of your folding prop?
Do you know if it requires a larger one piece zinc behind the prop and then a 3 piece split ring zinc towards the front of the prop?
-- Erik
« Reply #3 on: December 09 2016, 06:46 »
Mine is Volvo Penta 3-blade, did not check the diameter and pitch.
This model has a one piece ring anode behind the prop and line cutter, which is actually specific to the drive leg and a 3-piece anode attached to the prop body.
Images from back home, where the prop has been polished after being taken apart. Just noticed that there is a significant difference in blade shape and swivel pin locking screws compared to yours. My screws are 3 pcs cylinder head allen screw, where the cylinder head prevents blade pin from escaping. You seem to have 6pcs allen set screws, that physically push the blade pins?
BR,
Tommi
« Reply #4 on: December 09 2016, 12:30 »
Extend the life of your anodes by 100% see photo. This is in my older forum entries.
Hope this helps
Bav 38
« Reply #5 on: December 09 2016, 18:46 »
-- Erik
Important you replace the ring anode on the saildrive immediately. You can already see corrosion starting on the housing because the anode is nearly expired and is probably not making good contact with the housing.
As far as I know there is not a split anode conversion for a 120 drive so you have to remove the propeller. You can increase the life of the anode by wiring a hanging anode to the gear box housing for use when the boat is moored. MG Duff are the anode experts and you can buy a hanging anode (as well as the ring anode) from them.
