Panel switch no. 13
Author Topic: Panel switch no. 13  (Read 7415 times)
Ianburtoncamera
    • Award Winning Adventure Film Productions
  • Boat Model: Cruiser
Panel switch no. 13
« on: October 24 2016, 11:35 »
Hi.
I've a 2001 bav40, the switch panel has a mystery switch which I have spent quite a lot of time trying to find its use  ???
Number 13 doesn't seem to do anything.
Is there any one with any ideas?
Could it be an optional extra that I don't have fitted on this boat?
Ian
🌅  2001 Bav 40 Cruiser 🌌
Re: Panel switch no. 13
« Reply #1 on: October 24 2016, 11:56 »
Think you will find that is the cigar lighter type 12v socket with a 5 amp fuse.
Ianburtoncamera
« Reply #2 on: October 24 2016, 12:00 »
The cigarette lighter is powered by switch no. 8 (frei 8A). unless there is another lighter socket somewhere on the boat.
the socket switch 8 services is just below the plotter on the nav table.
Hmmm ???
Ianburtoncamera
« Reply #3 on: October 24 2016, 12:19 »
Also, I haven't worked out what switch number 16 operates either, but I am hoping that it's free.
When you have more electronics than switches, what does anyone do to turn them on and off? has anyone ever installed a new switch panel somewhere?
« Reply #4 on: October 24 2016, 14:12 »
Switch 13 is for entertainment [radio /cd /tv] Geoff
Ianburtoncamera
« Reply #5 on: October 24 2016, 14:16 »
Cheers Geoff, but my CD player works when I turn on switch number 15.  :)
« Reply #6 on: October 24 2016, 14:19 »
My switch 13 (same panel) is for the tricolor light and has an appropriate symbol for it. Yours looks more like a heater symbol, so possibly there was/is a heater of some kind (diesel, propane, electric stove ignition, etc.)?
"frei" means "free", so if you connect these to anything, you should print a label and stick it over it to tell what they're for :)
My switch 16 is indeed free now (it was previously used for a bodge-fix to switch off the chartplotter, which had a non-working power button).
If you really want to know for certain, follow the wire!
Ianburtoncamera
« Reply #7 on: October 24 2016, 14:27 »
Ah, yea, it could be the stove ignition, It was suggested by the previous owner that it could be heating, but the Eberspacher diesel heater works with just the batteries switched on, so I am going to try the stove ignition, as I had not thought about that, The stove buttons do have an electronic ignition symbol on it so that could be correct. thanks.
I'd sussed the Frei/free translation, well assumed anyway but good idea to stick a label over them.
Thank you :)
« Reply #8 on: October 26 2016, 08:14 »
My switch 13 with identical symbol is for heater - but most likely this is aftermarket installation by the broker.
The "Frei" for our boat is used for UHF radio and UHF / TV antenna amplifier
Tommi  - with a B40 2001 as well
Ianburtoncamera
« Reply #9 on: October 26 2016, 10:19 »
Thanks Tommi
It's not helpful when things like this aren't standard, like the symbols on the switches.  >:( pfft!
I will try the stove ignition on Thursday evening, and then trace the cables from the back of the panel and see if I can follow them.
Kibo
  • Boat Model: Vision 46
« Reply #10 on: October 26 2016, 13:16 »
Ian, on my boat there is a similar symbol on a switch (not exactly the same but very close) and it is for the propane line shut off solenoid valve; unless the power is on the solenoid closes the valve for the propane as a safety measure. The solenoid valve is usually situated very close to the propane bottle itself. Mine is right next to the regulator in the tank locker. This automatic solenoid is mandatory in US market boats and in most charter boat specs I believe.
You might not have a solenoid valve installed depending on the original options chosen or the market the boat was supplied to originally.
I think that usually the igniters on gas ovens/hobs are either piezo crystals or battery operated.
Hope that helps.
Ian
Ianburtoncamera
« Reply #11 on: October 26 2016, 13:55 »
Helps very much Kibo thank you. Yes I guess it would be for an optional solenoid, but this boat was never for charter, so that's why it hasn't got one.
Thanks for that :)
Laysula
  • Boat Model: 350 lagoon
  • Boat Year: 1994
« Reply #12 on: October 27 2016, 13:07 »
Have you looked at the back of the panel to see whether it is actually connected to anything. We have several unconnected switches on our panel. (1994 350 lagoon)
« Reply #13 on: October 29 2016, 05:56 »
...Yours looks more like a heater symbol...
Clearly. The function will be shown on the wiring diagram in the manual.
Ianburtoncamera
« Reply #14 on: October 31 2016, 10:01 »
Thanks Nigel, But I can't make head nor tail of the manual, those pages are very tatty.
Also it's not the stove ignition :(
heywoodp
  • Bavaria 38 Ocean 2000
  • Boat Model: Bavaria Ocean 38
« Reply #15 on: November 16 2016, 20:01 »
On my Bav 38 Ocean, there is a heater symbol against switch 13 although looking at the rear of the panel, nothing is wired to it
