B44 2003 interior wood type?
Author Topic: B44 2003 interior wood type?  (Read 3950 times)
Needsailing
« on: October 10 2016, 14:18 »
I would like to make up some wooden restraints / fiddles the same as the ones in the galley. Does anyone know what the wood is or something that will end up looking similar. Thanks
Re: B44 2003 interior wood type?
« Reply #1 on: October 10 2016, 16:13 »
If it is the classic early 2000s interior the panels are sapelee [mahogany] the trim like fiddles are laminated mahogany . Geoff
« Reply #2 on: October 10 2016, 22:35 »
There are many different variations of mahogany so you need to look through stock to find a match, although you can use wood dye such as Colron to adjust the colour. A satin finish varnish is good to blend in with the original. I use Ronseal as it is easy to apply and lasts well down below. The section in front of the galley is profiled and it is worth finding somebody who has a spindle moulder to machine a matching profile.
s/y Susanne
  • Boat Model: Bavaria 44/3
« Reply #3 on: October 17 2016, 09:14 »
We fitted uprights in a similar hardwood but have strung two lengths of elastic shock-cord end to end and drilled through the two uprights instead of fitting a removaeable bar. or two This allows us to restrain a good collection of books and stuff when sailing while allowing easy access for stowing or removal.
As the wife insisted on a reef being taken as soon as anything ever moved from the starboard shelf the elastic has allowed a few more knots of wind to rise before the command is given!
B44/3  2002 (boatshow model)
Stewart
