Volvo 2020D water pump?
Author Topic: Volvo 2020D water pump?  (Read 4183 times)
« on: September 04 2016, 11:53 »
[Split from http://www.bavariayacht.info/forum/index.php/topic,413.0.html by Nigel]
Does anyone know specifically which raw water pump is fitted to the MD2020 D engine, mine is from 2002, and the bearing and seal identification numbers. The seal on mine has just gone and needs to be changed. Thanks for any help.
Re: Volvo 2020D water pump?
« Reply #1 on: September 04 2016, 12:08 »
see here:
http://www.keypart.com/volvo-penta/diesel-engine/md2020d/20002005
Bought several times in the past from them - very helpful and respond by mail.
One time I was not sure about a certain part - sent them some info from the engine nameplate and they sorted this out.
« Reply #2 on: September 04 2016, 12:30 »
Many thanks Lyra, I'm not sure if it's just the seal ring or if I need the bearing as well (which I probably do), and whether the "sea water pump wear kit includes the bearing, so I'll contact them in the morning. Thanks again.
« Reply #3 on: September 05 2016, 21:45 »
Thanks again Lyra for the tip, I've ordered the seawater pump shaft kit which includes a replacement shaft, two bearings, two circlips, and a bearing seal. Also ordered was a set of new cover plate screws. Cost £72.69 including postage. Now for the fun part of fitting it 👹
