Difficulty shifting D2-55 into neutral
Author Topic: Difficulty shifting D2-55 into neutral  (Read 7297 times)
jeff.sailor
« on: May 30 2012, 15:49 »
When motoring at slow speed, while docking, it's hard getting the shifter in neutral.  No problems while motoring at normal speeds.  Anyone else notice this behavior and have a fix to suggest?  Boat is a Bavaria 38 Cruiser, vintage 2005.
Re: Difficulty shifting D2-55 into neutral
« Reply #1 on: June 01 2012, 10:01 »
When motoring at slow speed, while docking, it's hard getting the shifter in neutral...
Do you mean the button on the side, or just getting the telegraph lever vertical?
KAOS
  • Boat Model: BAVARIA 38
« Reply #2 on: June 01 2012, 10:11 »
Try and lubricate control lever assembly and the cable. if that does not work i would disconnect the cable from the saildrive gear box and operate it manually to see if the same happens but my instinct is pointing more to the lever/cable.
jeff.sailor
« Reply #3 on: June 06 2012, 04:12 »
Admin, I mean getting the lever into the position where it shifts out of gear and into neutral.
Kaos, thanks, I'll try the lubrication and see how it goes.
Jeff
« Reply #4 on: June 10 2012, 14:40 »
Yes, try the lube. And I'm Nigel by the way :)
jeff.sailor
« Reply #5 on: June 19 2012, 03:06 »
Thanks all, lube did the trick.  Jeff
