Automatic Bilge pump wiring diagram wanted
Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Automatic Bilge pump wiring diagram wanted (Read 3879 times)
Harveyhall
First Mate
Boat Model: 36 Cruiser
Boat Year: 2005
on:
June 02 2016, 06:24 »
We recently purchased a 2005 36 Cruiser. I would like to change the manual bilge pump setup to an automatic pump. I am assuming that at this time it is a manual (on/off). Is it possible to use the same panel switch/breaker or will I need to add a 3 way switch?
Logged
Old Salt
Boat Model: B36
Boat Year: 2004
Re: Automatic Bilge pump wiring diagram wanted
Reply #1 on:
June 02 2016, 07:49 »
I simply connected a float switch directly to the house battery. This is in parallel to the manual switch in the panel.
By default it will be the float switch that operates the pump. If for some reason I want to operate it manually I do it from the panel.
I also connected a buzzer in parallel to the pump to get an audible signal when it operates.
Logged
Old Salt
Boat Model: Bavaria 33
Boat Year: 2015
Reply #2 on:
June 02 2016, 14:26 »
If you really want an automatic pump then it needs to be "always on", therefore wired direct to the battery. However, unlikely to ever need it as most Bavarias are dry. If you are getting water in the bilges, stop the source.
Logged
Harveyhall
First Mate
Boat Year: 2005
Reply #3 on:
June 02 2016, 15:54 »
Excellent. For some reason I couldn't look at the problem from a different point of view rather then deal with the panel. Of course it needs to be direct to the house or a direct house bus... Thank you both.
I also like the buzzer idea as at times I am away from the boat for a couple months in our winter and will have others checking on the boat in the water.
I love the fact that the boat has a dry bilge, although the admiral has found a whole new storage potential...
Logged
Old Salt
Boat Model: Bavaria 38 Cruiser
Boat Year: 2009
Reply #4 on:
June 03 2016, 00:04 »
Be careful what you store in the bilges. Anything likely to flake could clog the pump when you most need it. The replica of the "Bounty" sunk in the Atlantic, partly because they had not removed the sawdust/wood shavings from the recent refit. Clogged the bilge pumps.
If bilges have any water in them, you have a problem. Bavaria bilges should always be dry. We vacuum the dust from our bilge on a regular basis.
Logged
R.I.P.
Old Salt
Boat Model: Bavaria 47
Boat Year: 2000
Reply #5 on:
June 04 2016, 12:33 »
Battery, fuse, float switch, pump, battery return. Manual switch overrides float switch.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
