laminated floor repair
Author Topic: laminated floor repair  (Read 4067 times)
« on: May 14 2016, 16:37 »
The plywood flooring has a thick lamination to it with a mock holly and teak pattern - its fairly brittle so  if something heavy  gets dropped on it the surface is likely to  chip - these chips now need filling with a material that's as hard wearing and a good colour match. Has anyone discovered a product for this?
Re: laminated floor repair
« Reply #1 on: May 15 2016, 09:12 »
To repair some screw holes I did mean to experiment with resin and pigment, but in the end I just used wood filler. Easy to replace when it fails.
« Reply #2 on: May 15 2016, 10:08 »
was the colour a good match and what product did you use
« Reply #3 on: May 15 2016, 15:56 »
For the brown you might try mixing epoxy with microballoons which are red/brown colour, or use a gel coat tint with some silica in the epoxy to thicken it.
« Reply #4 on: May 17 2016, 20:52 »
on another boat I used Ronseal wood filler  but the 2 part stuff has only 3 colours and assumes a stain will be applied which I have doubts about Ronseal also do  a 1 part multipurpose filler which more colours but I wonder how hard the finish is. The micro balloons I have aren't a good colour match - can you get these in different shades?
« Reply #5 on: May 18 2016, 10:12 »
Microballoons from Blue Gee in Poole are brown - as are West Systems. You can alter the shade of brown by adding a white filler such as Collodial Silica or wood fibre. You can also get pigments to add to the epoxy, but not sure whether a dark brown is available.
« Reply #6 on: May 18 2016, 11:40 »
I think good match can be achieved using epoxy with sawdust (actually sander dust) of a wood with similar color.
