Additional central mooring cleat
Author Topic: Additional central mooring cleat  (Read 7217 times)
wolfand
  • Boat Model: 42 cruiser
« on: May 11 2016, 08:58 »
Hello, I own a 39 Cruiser and I'd like to add the middle boat cleats. Did anybody do this job?
Baltic
  • Boat Model: B39
Re: Additional central mooring cleat
« Reply #1 on: May 11 2016, 11:34 »
Yes...
I add those some years ago.
« Reply #2 on: May 11 2016, 13:03 »
There will probably be an aluminium plate bonded in underneath the deck where the cleat goes. so you need to drill and tap to suit the mounting screws. Make sure you seal the cleat and use Duralec on the screw threads to reduce the chances of corrosion.
wolfand
« Reply #3 on: May 11 2016, 15:18 »
Thanks for your return. Baltic, I suppose you removed some furniture inside to perform the job, am I correct? Was it a difficult task?
« Reply #4 on: May 11 2016, 23:00 »
No. You won't have to through bolt it. As I said above there will be an aluminium plate boded into the deck in the raised area where the cleat goes. You can check its location by using one of those devices used to find cables in walls. Drill and tap (think they will be M8 for that size cleat) and use set screws.
wolfand
« Reply #5 on: May 12 2016, 07:33 »
Thanks for your suggestions, will follow!
Baltic
  • Boat Model: B39
« Reply #6 on: May 12 2016, 07:51 »
Wolfand
Quite a easy to install
Need not  any aluminium plate search.
Those are there. As well possible to see inside of the boat.
Just remove those two panel top of the locker.  (picture yellow cleat.PDF or cleat_install.jpg)
I used original cleats.
Those are "bolt" models.
My opinion. It is better use bolts instead of screws.
Starboard.
Just drill holes. And install cleats.
Port side. Little bit more complicated.
Toilet locker roof prevent to install nuts. (Or it is very difficult..)
I just drilled about 1" holes to the roof. (green)  Via those holes it was easy to use washers and nuts.
When you drill cleat holes itself. Use long drill. And make first 8mm holes to the locker roof.
After that increase those from inside.  For example to 1"
Later panel will cover the holes.
Below some pics.
1" hole.  I used hole drill and ordinary small ratchet wrench.
wolfand
« Reply #7 on: May 12 2016, 15:21 »
Great, thanks a lot Baltic for your comprehensive and detaild explanation.
Anthony
« Reply #8 on: May 13 2016, 04:31 »
have also done this and prefer to drill out the hole in the embedded aluminium plate and use stainless washer and stainless nylock nut on the underside... of course with tefgel and use sikaflex to seal (not silicone).
mikeiso1192
« Reply #9 on: May 13 2016, 10:03 »
I concur with Anthony on this.
Access on my B38 2004 was not too difficult so I bolted right through, sealed with sikaflex and load spread with large ss washers.
Mike
ZhuHai
« Reply #10 on: May 16 2016, 09:30 »
Did it 2 years ago.
On my boat, B36 2002, Bavaria didn't use stainless screws to hold the locker back panels so they were rotten. Some might be difficult to remove without damaging a bit the panels.
