Check the raw water inflow
Author Topic: Check the raw water inflow  (Read 3648 times)
Anthony
« on: April 25 2016, 10:01 »
I had a problem with exhaust water becoming noticeably reduced and hotter.
Removed the raw water inlet pipe and checked the seacock flow... minimal!! A quick prod with a long screwdriver and suddenly a very strong inflow. Now the exhaust flow is pletiful and cool to the touch.
This is one of those marine growth areas you cannot check from outside the hull as it is inside the saildrive leg.
Probem solved but best approach is via the rear cabin under the beds.
Re: Check the raw water inflow
« Reply #1 on: April 25 2016, 10:44 »
Tony, you won't have solved the problem, only temporarily cleared it. Check also your cooling water filter as some of the filters fitted are of a very poor design which can allow mussel shells through to the pump and beyond. A recent posting, and one I submitted a year or two back, noted mussel shells being found at the entrance to the cooling water tube nest and blocking much of the flow of water. When your boat is on shore you need to look through the cooling water slots within the sail drive, and to remove whatever marine growth you see within that area, and do it every time your boat is ashore. I have used a high pressure water jet with some success, and the other possibility is a long thin bottle brush (eBay), but you do need to check the flow of cooling water fairly frequently when you are on the move and under power. The first indications I had of a problem was where I wasn't sure if it was smoke I could see coming out of the exhaust or if it was steam. It turned out to be steam!
Several of the boats onshore this last winter I noted they had wrapped their saildrives in plastic bags, I don't know what if any benefit this may provide, but on the down side it would maintain a moist atmosphere within which, I'm guessing, might be sufficient to support the life of these little critters, and possibly sufficient to allow them to procreate !!!
« Reply #2 on: April 26 2016, 15:17 »
If it is a persistent problem as it is in some locations, there is always the alternative of adding a separate water inlet via a skin fitting and seacock.
Anthony
« Reply #3 on: April 28 2016, 09:42 »
Thanks Salty, but there is no way a mussel shell would get thru my filter.
I do like Symphony's idea of a parallel raw water intake feed. I also think a 2-way tap on the inlet could allow a fresh water flush to be incorporated.
