Volvo D130s water pump cover
Author Topic: Volvo D130s water pump cover  (Read 6479 times)
ANTREVELL
« on: April 18 2016, 21:53 »
Does any one know if the raw water pump cover is available as pattern part
Regards Tony   Pegatha
Re: Volvo D130s water pump cover
« Reply #1 on: April 19 2016, 07:57 »
Do you mean the impeller cover? if so, and you can't find one, the SpeedSeal system comes with a compatible replacement  ;)
« Reply #2 on: April 19 2016, 13:04 »
Another vote for replacing it with a Speedseal. Far superior to the plain cover.
« Reply #3 on: April 19 2016, 13:27 »
Here is mine, its great, impeller life is extended as well mine is on its 3rd season .
Bav 38
ANTREVELL
« Reply #4 on: April 19 2016, 20:18 »
That sounds good to me . Can you tell me where I can purchase one of these.  Am I assuming it is a complete new pump or just the impeller cover.
Regards Tony
« Reply #5 on: April 19 2016, 21:18 »
Just put speed seal into google, get the upgraded one.
Bav 38
« Reply #6 on: April 20 2016, 16:27 »
Regards Tony
Mail order from www.spedseal.com. It is just the cover, but unlike the simple brass plate it is machined solid and most importantly rather than the silly little screws (that either break of get lost) it has big thumb screws and just slides on and off. The seal is with a na O ring rather than a paper gasket. The upgraded model also has a plastic ring inside that enables the impeller to run even if dry - an extra precaution.
« Reply #7 on: April 20 2016, 19:59 »
...Mail order from www.spedseal.com.
...sorry to correct you, Symphony. I think that should be www.speedseal.com . Perhaps a wibbley keyboard...?    :tbu
DT
« Reply #8 on: April 21 2016, 12:41 »
Thanks. I need one of those , clever simple idea.
Domi409
  • Boat Model: B45
« Reply #9 on: April 24 2016, 18:27 »
It is available at USHIP:
http://www.uship.fr/couvercle-de-pompe-a-eau-speedseal-art_fr_1995.html
Several models depending on your engine type.
GeoffV
  • Boat Model: Bav 37 Cruiser
  • Boat Year: 2016
« Reply #10 on: April 24 2016, 19:17 »
Just to add it only takes about 20 mins to fit and to replace an impeller takes less than that oncw fitted.
Geoff
ANTREVELL
« Reply #11 on: April 24 2016, 20:53 »
Thank you for all the info. I have now ordered one
Regards Tony
