rudder bearing lubrication
Author Topic: rudder bearing lubrication  (Read 3641 times)
« on: April 07 2016, 18:52 »
When the boat came put of the water, there was some play in the rudder and I thought to replace the bearings but, as the boat yard has a ground surface of pristine concrete this would involve a lot of hoisting. Now after some years there is no longer any play in the rudder, the wheel is stiffer to turn than before. I have lubricated the steering cables - no change - so wonder if I should grease the rudder bearings and if so how? Or will sea water after launching provide a lubricant?
Re: rudder bearing lubrication
« Reply #1 on: April 07 2016, 20:10 »
Put "rudder bearing maintenance" in this sites serch engine.
Oysseus
Bav 38
« Reply #2 on: April 11 2016, 08:07 »
Nothing came up - I tried various phrases on the theme
« Reply #3 on: April 11 2016, 08:10 »
Open 'Bavaria Yacht Info Forums' page and enter the search from there  ;)
