saildrive anode bolts
Author Topic: saildrive anode bolts  (Read 4185 times)
« on: March 24 2016, 12:57 »
Its that time of year again and I will share with you a trick I have used for years. The anode on the leg is attached with 2 Phillips headed bolts. They are notorious for stipping when trying to undo them.
So fit 2 hex headed bolts M6 x 16mm.
You can buy these from tool station for £2.57 for 50, your volvo agent will charge you up to £2.59 each for a Phillips headed bolt. Its a  no brainer.
Hope this helps.
Bav38
Spirit of Mary
Re: saildrive anode bolts
« Reply #1 on: March 24 2016, 14:31 »
Hope this helps.
Bav38
I see on the bolt head that you use A2 (304 SS) quality,. Also the plastic bag shows this. This is too low quality SS for seawater. It should be A4 quality which equals 316 SS!
However the idea to use internal hex bolts or torx is good.
Ger
« Reply #2 on: March 24 2016, 14:45 »
They only need to last one year max, not seen any deterioration on any of the bolts I have used in 7 years of doing it. Your choice.
