Dear All,
For ease of use, below are the lists of rudders (complete and shafts), bearings, housings.
We also have some fiberglass shells, raw shaft material (alu, steel long bars), core cell...
All interested contact me on warehouse@svpyachts.com
Rudder section:
RUDDER AXLE BAVARIA 32 NC - rudder shaft
RUDDER HANSE 320&350 TILLER , SHALLOW KEEL - rudder
RUDDER HANSE 320&350 TILLER - rudder shaft
RUDDER AXLE SALONA 40 - rudder shaft
RUDDER AXLE B 38 MATCH (FI 64) - rudder shaft
RUDDER BAVARIA 31.1 CRUISER ('07)
RUDDER AXLE BAVARIA 38/2K+3K - rudder shaft
RUDDER DELPHIA 33 STEERING ('07)
Hanse 320 & 350 - rudder shaft and complete rudder
Bavaria 34.1 C - rudder
Bavaria 42/46 rudder
Bavaria 38.1 C
Bavaria 36/26
B vision 42/46
Bavaria 47 rudder
Bearings - housings:
120X64X81 B 31/2K, 32/2K, 34/3K - LOWER BALL BEARING
65X40X40 B 37C, 36/2K, 35/38/42M - UPPER BALL BEARING
98X68X60 B 37/2K - LOWER BALL BEARING
140X88X90 B 42 H/O - LOWER BALL BEARING
140X72X90 B 47 AC/O -LOWER BALL BEARING
125X74X80 B50H,46AC ('04) - LOWER BALL BEARING
110X74X70 B38 H - LOWER BALL BEARING
110X78X70 B41E/H, B38E - LOWER BALL BEARING
110X56 B 37/2K - UPPER HOUSING
120X60 B 40AC,44AC,47AC,50H- UPPER HOUSING
128X125 B 37C,39C,40 AC/O - LOWER HOUSING
159,6X151 B 47 AC/O - LOWER HOUSING
142X139 B 44AC/O,50AC,S 40/45 - LOWER HOUSING
100X120 B 38 - LOWER HOUSING
110X73X70 B 37 KROGLA - LOWER BALL BEARING
98X60X60 B 350 - LOWER BALL BEARING
125X88X80 B 44 H - LOWER BALL BEARING
120X62X81 B 32 H - LOWER HALFBALL BEARING
139X170 B 42/46/50 AC '04, 49AC - LOWER HOUSING
125X78X80 B 49 AC - LOWER BALL BEARING
98X64X60 B 32 AC - LOWER HALFBALL BEARING
140X56 B 35/38/42 MATCH, B 37C - UPPER HOUSING
110X64X70 B 38 M - LOWER BALL BEARING
110X64X70 bearing with rollers
110X68X70 B 38 MATCH/42 MATCH - LOWER BALL BEARING
140X60 B 40V,42/46/50 AC ('04 - UPPER HOUSING
120X58X88 B 30C,37C - LOWER HALFBALL BEARING
140X25 B 31.1C,B30 - UPPER HOUSING
120X63X88 B33/2K C, 34.1 C - LOWER HALFBALL BEARING
125X68X80 B 40V,42AC('04),44 AC/O rolers - LOWER BALL BEARING WITH ROLLERS
120X59X88 B 31.1 C - LOWER HALFBALL BEARING
110X63X70 B39C,38AC,40AC/O rolers - LOWER BALL BEARING WITH ROLLERS
125X83X80 B 50 C+V rolers - LOWER BALL BEARING WITH ROLLERS
LOWER BALL BAVARIA 32 CRUISER - LOWER BEARING
LOWER HOUSING BAVARIA 32 CRUISER - LOWER BEARING
UPPER BALL BAVARIA 32/36/40 NC - UPPER BEARING
UPPER HOUSING BAVARIA 32/36/40 NC/42/46NV - UPPER BEARING
LOWER BALL BAVARIA 36/40 CRUISER - LOWER BEARING
LOWER HOUSING BAVARIA VISION 42/46 - LOWER HOUSING
120x63X55 HALF DOME
118X64X55 HALF DOME
120X59X88
125X88X80 LOWER BALL BAVARIA 36/40 CRUISER - LOWER BEARING
86X58X50
125X72X80 B44 ROLLERS - LOWER BALL BEARING WITH ROLLERS
137X96X81
110X150 ALU TUBE FOR LOWER BEARING BAVARIA 32
TUBE FOR WATER LOCK
115X107 B 37/2K - LOWER HOUSING
120x63x88 BALL BAVARIA
140X98X90 BALL BAVARIA
NUT 139X170 (005303)
NUT 75X47X15
NUT 98X46X15 WITH EDGE
NUT M42X15
NUT 79X47X15
NUT 75X37X15
ALUMINIUM TUBE FOR LOWER BEARING B42/46N
ERTALYTE NATURAL TUBES - (72x29), (140x70), (160x80), (82x35), (65x35)
ERTALYTE BLACK ROUND RODS DIAMETER 10 MM - material
9x54,4 - already made bearings - rollers
9x71 - already made bearings - rollers
7x59,4 - already made bearings - rollers
9x63,4 - already made bearings -rollers
8x51 - already made bearings - rollers
6x58,5 - already made bearings - rollers
9x61 - already made bearings - rollers
10x44 - already made bearings - rollers
7x65 - already made bearings - rollers
9x51,2 - already made bearings - rollers
Hope this helps, Peter
