HOUR LOG METER ON THE RPM GAUGE TACHOMETER
Author Topic: HOUR LOG METER ON THE RPM GAUGE TACHOMETER  (Read 8297 times)
russ
  • Live the Dream
  • Boat Model: Bavaria 42 cruiser
« on: April 21 2012, 01:12 »
I have a Volvo D55 with a Sail Drive on my 2006 Bavaria 42 foot cruiser. The control panel has a tachometer and in the Tach is the hour log and the log is digital. My log appears sometimes but most of the time it is blank. Does anyone know how to solve this problem as I now must use a watch to record the hours.
Re: HOUR LOG METER ON THE RPM GAUGE TACHOMETER
« Reply #1 on: April 21 2012, 11:03 »
A known problem. You may be able to fix it temporarily by putting the unit in the airing cupboard for a few days, or replace the hour meter. For instructions, go to the Bavaria Yacht Info main web page, and click Downloads.
russ
  • Live the Dream
« Reply #2 on: April 21 2012, 16:40 »
 :)THANK YOU NIGEL I have ordered the paert from Farrell. Do you know where I could order a fuel sensor for the sensor in the tank?
CRYSTAL
  • Boat Model: B33C
« Reply #3 on: April 21 2012, 20:52 »
Nigel,
Any way of getting the newer model (2007) of Tachometer disassemble instructions?
This way, maybe we can hard wire a bigger buzzer - one that can be heard.
thanks,
Hratch
Hratch
CRYSTAL I
« Reply #4 on: April 22 2012, 00:54 »
Quote
I bought mine from www.peachment.co.uk - on my boat it is P/N 226.801.15.1 VDO Fuel Sender (Float Arm Type)
Quote
The only way to get disassembly instructions is if someone takes one apart. Your buzzer is inside the tachometer? Are you sure?
CRYSTAL
  • Boat Model: B33C
« Reply #5 on: April 24 2012, 21:04 »
Hi Nigel, buzzer is inside. see attached pic.
damn thing is also sealed nice and tight no screws and does like to be screwed around! :o
So any ideas?
Thanks,
Hratch
Hratch
CRYSTAL I
