VPP polar charts
Author Topic: VPP polar charts  (Read 12204 times)
grossifs
  • Boat Model: Bavaria 40 Cruiser Avantgarde
  • Boat Year: 2012
VPP polar charts
« on: December 18 2015, 11:10 »
I've asked to Bavaria but I haven't got an answer: anybody knows how to obtain the tables of the Polar charts for Bavaria 40 New Cruiser Farr?
Re: VPP polar charts
« Reply #1 on: December 21 2015, 09:12 »
Try Google there are several sites that have VPP charts. I found one for the 2009 B 40 Cruiser.
Good luck
SV Synergy
B40 2009
grossifs
  • Boat Year: 2012
« Reply #2 on: December 21 2015, 12:24 »
google has been my first try...but the ones I ve found are not related to the features  of mine avantgarde 40 with rolling mainsail etc...
« Reply #3 on: January 02 2016, 04:31 »
It is not likely that you will find a polar chart specific to the rig options you have. Finding one that is close is your best staring point. Then record actual performance of your vessel and modify the polar chart to match.
SV Synergy 2009 B40 Cruiser
« Reply #4 on: January 02 2016, 14:06 »
Unlikely that many owners would be interested in polars for that sort of boat. There are computer programmes you can get to calculate theoretical polars from which you can then derive actuals from your own experience of your boat.
« Reply #5 on: January 03 2016, 21:28 »
  Mmmm,?  Why shouldn't cruising sailors be interested in improving the performance of their boat?
« Reply #6 on: January 03 2016, 22:53 »
"Why shouldn't cruising sailors be interested in improving the performance of their boat?"
Perhaps cruising sailors are quite happy and content with the performance of their boats as they are. Perhaps all they want to do is to sail gently, sedately and safely without putting any more stress or strain on the boat and its rigging, and if it takes a bit longer to get from one point to another, the benefit is in taking part rather than trying to arrive first. Each to their own, but for those that want such a chart, good luck. I hope you find what you want, but while I'd be interested to see what information can be gained from such a chart, I won't be upset if I never see one.
Aquila
  • Boat Year: 2012
« Reply #7 on: January 04 2016, 10:19 »
of course polars are particularly useful for weather routing should you be doing any decent distances. I think they should be available.
« Reply #8 on: January 04 2016, 11:00 »
The OP has chosen a boat with in mast furling, so would guess that high performance under sail is perhaps not high on his list of priorities. For most cruising sailors information on polars is as interesting as a 0-60 time for a car. There is a lot more to enjoyment out of a cruising boat than squeezing the last few fractions of a knot of speed.
« Reply #9 on: January 04 2016, 15:18 »
There's a big difference between being interested in improving the performance of your cruiser and squeezing the last fraction of a knot out of her. I guess that's why most cruisers would avoid buying an ex-racing boat where overloading may have been an issue.
  Aquila's point is a good one , having a polar chart means you know your best point of sail to avoid some 'orrible weather, or to choose the fastest possible passage to obtain shelter if things look like going pear shaped.
« Reply #10 on: January 11 2016, 01:10 »
Aquila has nailed it. I use polars for local routing when cruising around the Gulf St Vincent and further afar. Perhaps a bit of a hangover from race routing, and overkill, but it does provide peace of mind for passage planning.
SV Synergy B40 Cruiser 2009
grossifs
  • Boat Year: 2012
« Reply #11 on: February 29 2016, 10:10 »
That is the point... but the question is: where can I find them?
« Reply #12 on: February 29 2016, 13:07 »
You could try contacting Farr Yacht Design via their website. Blur was where I found a Bavaria 38 polar which I have used for a starting point (attached). Other than that a pen and note pad to gather all the information.
grossifs
  • Boat Year: 2012
« Reply #13 on: March 21 2016, 12:41 »
good idea!
