Webasto AC reverse heat?
Author Topic: Webasto AC reverse heat?  (Read 4516 times)
SofiaB
  • Boat Year: 2016
« on: December 11 2015, 02:49 »
I just placed an order for a Vision 46 with (3) AC units (total 30K BTU).  I was going to install an AC unit in my old boat which had a reverse cycle for heat.  Does anyone know if the Webasto AC units have a reverse cycle for heat?  There is temp controls; does a higher than ambient temperature kick in the units to provide heat?
If not, does anyone know about installing a heat unit that works with the new Webasto AC units?
Thanks!   S.
Cheers,  Stuart  (Sofia)
Stuart
Re: Webasto AC reverse heat?
« Reply #1 on: December 13 2015, 00:26 »
Hi Stuart (great name by the way) Can't answer your question re the Webasto AC but if you add say a diesel heater, be aware that it requires a different duct than they use  for AC to handle the higher temps from the diesel heaters.
Stuart
SofiaB
  • Boat Year: 2016
« Reply #2 on: December 18 2015, 22:58 »
Stuart,
Thanks for that bit of information.  I may freeze in this boat in Ohio; I can't seem to get the info regarding the AC units.  I have someone in Germany working on getting some answers.
Thanks Again.  S.
