cleaning non slip deck
Author Topic: cleaning non slip deck  (Read 8655 times)
tony from dorset
« on: April 08 2012, 19:39 »
 I clean my boat ( bavaria 36 ) after every trip  , but i always have a dark stain where water drains at front of boat either side of forward cabin window  on non slip and on non slip either side of mast i have tried most cleaners didnt know if any body else has had this and if so any magic formula for shifting it.   The boat is mint apart from these two areas, any suggestions gratefully received
Tony
Re: cleaning non slip deck
« Reply #1 on: April 09 2012, 23:19 »
I ... have a dark stain where water drains at front of boat either side of forward cabin window...
If it's rust, which seems likely, use Oxalic Acid. Mix a 10% solution (10g to 100ml) and leave it on for 10-20 minutes. Also good for cleaning rust stains on stainless fittings.
AndyPandy
  • Boat Model: Bavaria 33 cruiser
« Reply #2 on: April 10 2012, 20:23 »
Hi Tony,
Same thing here mate. I got it clean with a 'magic stain pad' thing from the pound shop.
Brilliant result,
Good luck
Andy
tony from dorset
« Reply #3 on: April 10 2012, 21:08 »
No def not rust stain it is where rain runs off dirt mixes with water and leaves wide dark mark on non slip either side of mast and non slip either side of front forward cabin
AndyPandy
« Reply #4 on: April 11 2012, 19:14 »
Ii think it comes from the mast, maybe lube or summit :))
A duzzit will get it all off
tony from dorset
« Reply #5 on: April 11 2012, 21:11 »
hi andy  is that the same thing as the magic pad from the pound shop if so will give it a try
Tony
AndyPandy
« Reply #6 on: April 12 2012, 21:01 »
Hi Tony,
Thats them mate, they are really great,
let me know how you get on
Andy
njsail
Re: cleaning non slip deck (cleans teak too!)
« Reply #7 on: April 13 2012, 13:39 »
I stumbled across this stuff that is dual purpose for me.  The Starbright non-skid deck cleaner with PTFE cleans non-skid squeaky clean and as a side effect cleaned a lot of the dirt off my teak decks.  The run off from the PTFE I just scrubbed the deck a little and when I washed it off "poof" the decks were showing bare wood.  It was much easier than the two part deck cleaner which I wouldn't use again.  That stuff is just nasty.   Anyway I don't have any affiliation with these folks just wanted to let you know about the teak cleaning side effect.  It's not a perfect clean teak but it certainly worked nicely for me.
http://www.amazon.com/Starbrite-Non-skid-Deck-Cleaner-Protector/dp/B003CYTNPY
I need to pick some up to clean up this week for when I take the cover off and start the sprint cleaning rituals.  Oh the joy.
