Stainless lazarette latches, turn and lift style, original Bavaria
Author Topic: Stainless lazarette latches, turn and lift style, original Bavaria  (Read 5916 times)
They're exactly like these, except with a straight cam bar and for a 60 mm diameter hole: https://www.seascrew.com/browse.cfm?s=3842684
Used, in good condition, removed from my B40 Ocean due to upgrade to lockable ones. Got two, £10 each. Collection at Brighton Marina or can ship at cost.
markleuty
Hi  there,
I too am looking at upgrading my lazarette latches to lockable ones on my B40Ocean..
Would it be cheeky to ask from where you sourced your replacements?
I've put in these Osculati ones: http://osculati.com/en/cat/Scheda.aspx?id=26744 (No. 38.152.51)
Seascrew ordered and stocked them special for me and they're now in their system as reference 3815251: https://www.seascrew.com/browse.cfm?s=3815251
The lock is nothing special (every key is the same), but will keep an opportunity thief out. The key can be removed in locked or unlocked position. The compression spring on the lock bar is quite nice. They have an o-ring under the top lip, so I've sanded the protruding teak down to the level of the rest of the lazarette lid, put some silicon grease on and screwed it in tight. I checked after the last pouring rain and it wasn't leaking (so no sealant necessary).
