Valero 60A 14v alternator wiring on MD22L
Author Topic: Valero 60A 14v alternator wiring on MD22L  (Read 5022 times)
AB1707
  • Boat Year: 1997
« on: September 08 2015, 08:53 »
Hi all
I have had to put this alternator back on as my 90a one is kaput.
When the 90A went on the man told me he'd left off a yellow wire that wasn't needed on it.
This yellow wire is now unattached. I don't know where it attaches. It is live - using a voltmeter it shows the battery voltage and appears to run back to the battery.
Possibly connected my Rev counter & Engine hrs aren't working since the 60A went back on.
Anyone know? Picture attached
fdemei
Re: Valero 60A 14v alternator wiring on MD22L
« Reply #1 on: September 29 2015, 15:16 »
Hi man,
if do you have  the battery insolator  ( to charge main and auxiliary battery), The yellow wire ,MUST be connected to the auxiliary battery ( + ) .If do you have only one battery is enough to be connected to the alternato  output  (+ ) , but it must be connected, otherwise the output voltage grows more the 30 volt.
« Reply #2 on: September 30 2015, 09:41 »
The wiring diagram for your boat should show you where it goes.
AB1707
  • Boat Year: 1997
« Reply #3 on: October 15 2015, 12:21 »
Thank you gents, sadly no wiring  diagram
« Reply #4 on: October 15 2015, 17:44 »
Start a new thread: Bavaria 38 Ocean 1997: Wiring Diagram needed
« Reply #5 on: October 16 2015, 14:56 »
I now see that I have the same wire unattached and it is as follows:
1. This wire is the battery voltage sensing which makes sure that the regulator regulates according to the actual battery voltage.
2. When I bought the boat, the alternator had a yellow "pigtail" wire coming out of the regulator (this is the black&white part at the bottom left f your picture) - this sensing wire was connected to it, so if you have one you should connect to this wire (see attached picture).
3. Several months ago the regulator died and I had it replaced. the new regulator does not have this wire and the guy who fixed it said it was not necessary. I can only assume that the regulator senses internally the battery voltage off the +B terminal - not the best practice because this is the voltage before the isolator , which I believe drops about 1 volt. I will have to check the details next week.
