Bavaria 41 water tank
Author Topic: Bavaria 41 water tank  (Read 6620 times)
Cathy Davies
« on: August 12 2015, 22:33 »
Dumb question I know but how do you switch from aft water tank onto forward one on a Bavaria 41? Can't find switch!!
Cathy Davies
Re: Bavaria 41 water tank
« Reply #1 on: August 12 2015, 22:37 »
And is there an easy place to find an instruction manual if your charterer hasn't provided one?!
« Reply #2 on: August 12 2015, 22:40 »
It is a simple 3 position valve, probably somewhere in the loo. You will find the pump and changeover valve in one place. It is clearly shown in the handbook.
Cathy Davies
« Reply #3 on: August 13 2015, 06:01 »
Mm - problem, as I thought I'd said, is no handbook, hence trying to source one online. Have looked for something resembling a valve in both heads without luck but will keep searching.
B41
  • Boat Model: Bavaria 41
« Reply #4 on: August 13 2015, 07:07 »
If you have a B41 3 cabin, the 3 way valve is in the port-side toilet. when you enter it there is at the right a small hatch ( small seat at shower). Open the hatch. In the middle at the bottom under the holding tank there is a red handle. Turn it to the left : Aft tank. To the right : forward tank.
« Reply #5 on: August 13 2015, 08:13 »
Don't know this model, but basically you can do it by ear - turn on the water, listen for the noise of the pressure pump, locate it and most likely the 3 way valve is close to it.
« Reply #6 on: August 13 2015, 20:28 »
OK, we're a B34/2-cabin but our switch is under the sink. Worth looking there too.
p.s. and ours is not near the pump
« Reply #7 on: August 13 2015, 22:33 »
If it's this Bavaria 41 (Cruiser 41) you're talking about: https://www.bavaria-yachtbau.com/sailing-yachts/cruiser-line/cruiser41.html#techdata
It appears to have only one  (210 L) water tank. So it might be that you can't find the valve for the second tank because there isn't a second tank or valve. Otherwise, above hint to find the pump is good advice - the switch would be very near it (mine lives behind a little cabinet door in the aft cabin together with pump and pressure tank, but that's on a wholly different model).
« Reply #8 on: August 13 2015, 23:55 »
Simple way of checking is to see if it has two fillers. One will be at the stern and the other at the bow.
