Air Filter on Bavaria 30
Author Topic: Air Filter on Bavaria 30  (Read 3818 times)
chrisdaykin
  • Boat Model: Bavaria 30
« on: August 11 2015, 12:09 »
Anyone changed the air filter on a Bavaria 30 2007 (Volvo D1-20)?  The filter housing appears to be jammed up against the wooden bulkhead (forward of rear cabin) so tricky to get at rear attachment nut and to then remove the housing.  I may be missing something, so any help gratefully received.  Chris
Domi409
  • Boat Model: B45
Re: Air Filter on Bavaria 30
« Reply #1 on: August 13 2015, 10:24 »
Hi, on my previous boat, a B30C 2006 with D1-20, I could remove the nut from the rear cabin, by removing the wooden plate below the bed for access.
At the end, I did not change the air filter, it was not dirty, the air intake remains clean.
Dom
battuta
« Reply #2 on: August 31 2015, 06:34 »
I changed mine a couple of years ago (2009 B31 so essentially the same boat). You're not missing anything...it's really tough to do and I recall going at that nut "blind", by feel only, and in a very contorted position. Sliding the filter off is similarly tough and requires and angled pull with lateral torque.
The engine is way too tight a fit, which causes me angst when contemplating a possible sail drive gasket change down the road...
Good luck!
