Author Topic: Bavaria gas oven  (Read 5214 times)
stevem
Bavaria gas oven
« on: August 04 2014, 18:26 »
I have just had the righthand  gas ring fail.The problem us the flame failure device has stopped working. If you hold the gas tap in it works but the flame goes out when the knob is released.
Does anyone know if a flame failure device is available and if so from where.
Re: baveria gas oven
« Reply #1 on: August 05 2014, 10:32 »
Spares are available from  Socal (calor gas marine) southampton
stevem
« Reply #2 on: August 05 2014, 12:24 »
Thanks Mike I will contact them.
Regards,
Stevem
suibhne
  • Boat Model: 36
Re: Bavaria gas oven
« Reply #3 on: August 10 2014, 17:04 »
I think that its probably a bad earth connection to the thermocouple sensor.
Same thing happened to me.
I lifted the top poked around for a bit thought I had failed.
Reconnected everything and found to my surprise both rings were working.
iain789
« Reply #4 on: August 16 2014, 11:32 »
I had a similar intermittent problem last year. Spoke to a gas fitter about it while he was replacing the flexible gas hoses on the boat. He suggested turning the burner ring round slightly, and explained that sometimes the flame is not close enough to the thermocouple to heat it up sufficiently. Tried that and - so far - no problems this year.
suibhne
  • Boat Model: 36
« Reply #5 on: May 28 2015, 13:15 »
Same problem as last year very little flame even with full gas bottle.
Tightened up the nut underneath the thermocouple on both jets
Result gas flame strong on both burners.
