Author Topic: Bavaria 37 alarm sounds when engine stopped Volvo D1-30  (Read 4067 times)
cmack70
  • Boat Model: Bavaria
We have a Bavaria 37 with a Volvo D1-30 engine, when we hold the engine stop after the engine stop a alarm sound and a triangle warning is displayed.
I've check the wiring to the engine and all looks OK and engine start and runs without any issues.
I've also found it you press and hold the engine stop when the engine is not running the same thing happens.
Re: Bavaria 37 alarm sounds with engine stopped Volvo D1-30
« Reply #1 on: April 29 2014, 22:34 »
It could be that the engine idle speed at stop is set too low with the consequence being that the amount of charge coming from the alternator is below the level needed to re-charge the batteries. When I start the engine on my Bav 36, the alarms sound, but as soon as I move the throttle lever away from the stop position the alarm stops. Sorry, I've not actually noted what the idle speed on my engine is, other than it being significantly below 1000 rpm, once I've brought it up to 1000 the alarm stops. Hope that helps.
