Author Topic: removing the cam wheels ect  (Read 4008 times)
tckearney
  • Boat Model: B42
« on: October 31 2024, 10:44 »
Good day.  I have a very small water leak from the freshwater circulating pump  Bavaria 42 2000. .  This is behind the plastic covers on my MD22 55hp.  I have started the job and removed the cam belt, with all pulleys locked in position but cant remove the main crankshaft pully.  Is there a secret to getting the main lock nut off.  The boat is in the water so I cant put it in gear and lock the prop. How do you lock crankshaft so I can undo the nut.  Also I cant figure out how to lock the fuel injector pump once the injector drive wheel is off.  Is there any U tube videos. Thanks Terry.
Re: removing the cam wheels ect
« Reply #1 on: October 31 2024, 12:21 »
I believe MD22 workshop manual from may help https://nikimat.com/volvo_tmd_22_workshop_manual.pdf. Furhtermore some tips on how not to use Volvo special tools and still manage locking all timing components (incl. flywheel) are described in timing belt change DIY instructions at https://www.jeanneau-owners.com/hintsandtips/volvomd22lbtimingbelt.html.
..preparing for timing belt change within the next one or two seasons... have these links at my bookmarks :)
BR,
Tommi - s/y Anniina
« Reply #2 on: October 31 2024, 12:38 »
I can recommend getting the Haynes manual for the Perkins Prima (which is what the MD22 is, with some minor modifications around the heat exchanger):
Helped me a lot with this sort of job. It has all the right size drill bits that you can use instead of the Volvo special locking tools :)
mibbal
« Reply #3 on: December 23 2024, 20:18 »
Maybe too late, but still. I had the same problem when I was changing fresh water pump on my MD22. So, I just cut the cover above crankshaft pulley, so I can remove upper part of the cover (with all other pulley removed) and replace the pump.
Then I screwed back the cover. Yes, there is small crack on it now, but this saved me a lot of time and efforts.
« Reply #4 on: December 24 2024, 09:02 »
On the MD22, you can remove the cover without removing the crank pulley, you just have to wiggle it a bit.
mibbal
« Reply #5 on: December 24 2024, 12:14 »
I have MD22L-B, and it was not possible to remove the cover with pulley installed. That is why I decided to cut it, which I think is not a big problem.
