Author Topic: Bavaria 50 2005 cruiser Propellor Specifications  (Read 7267 times)
allyfiji
  • Boat Model: Bavaria 50
« on: September 10 2013, 00:49 »
My Prop has dropped off making passage in stormy seas - I wonder if anyone can help direct me to the specifications to urgently order a new one?  My yacht is a 2005 built bavaria 50 cruiser.  Appreciate any possible help.
Baltic
  • Boat Model: B39
Re: Bavaria 50 2005 cruiser Propellor Specifications
« Reply #1 on: September 10 2013, 09:03 »
Check attached list.
50cruiser
D2-75
150 S2
Fixed     18 x 16 G
Folding  20 x 14 E
Ziffius
« Reply #2 on: September 11 2013, 22:34 »
I went to these guys for advice as the damaged prop I had was not the recommended size for the engine I have, very helpful guys.
Tom Atkins
Parts/Sales Assistant
Volspec Ltd.
Woodrolfe Rd
Tollesbury
40th
Essex
CM9 8SE
(    Tel  01621 869756
(    Fax 01621 868859
* tom@volspec.co.uk
ΓΌ  www.volspec.co.uk
Viking
  • Boat Model: 50 Cruiser
« Reply #3 on: September 15 2013, 23:16 »
If you fail to find one, I have an unused one you can buy. (I replaced the fixed blade propeller with amfolsing propeller before my B50 (2008/2009) was launched in the water first time).
Just keep it in the cockpit locker as a spare now.
I (and the propeller!) am presently located in Spain.
allyfiji
« Reply #4 on: October 05 2013, 22:38 »
I am in the market for a feathering 18 by 16 right hander - in Fiji at the moment.   I had a 17 x 12  fixed left hander fitted in New Caledonia as an emergency. It's fine but makes an annoying whirring noise.
« Reply #5 on: October 07 2013, 10:32 »
You don't have a choice of LH or RH props for saildrives - they all go the same way. If you are going to buy a feathering or folding prop there are many different designs on the market so you need to decide what features you want and ask the manufacturers to recommend the size to suit your boat. The size you are suggesting sounds too small, but it does depend on the design you choose.
The whirring sound is quite normal for standard fixed blade saildrive props - it is the prop turning the gears when under sail. You can stop  it by locking the box in reverse. Not recommended by Volvo but many people do it. With a folding or feathering prop you can lock in gear because the shaft does not turn. However, usually the blades will fold or feather if stopped in gear and then put into neutral.
« Reply #6 on: October 07 2013, 14:29 »
A 120 saildrive will accommodate left or right handed props by changing the morse in binnacle. I have checked this with Volvo.
Not the newer sail drives as they have a different gear set up for reverse.
« Reply #7 on: October 10 2013, 08:17 »
Check attached list...
Looks interesting. Where did you get that?
Baltic
  • Boat Model: B39
« Reply #8 on: October 11 2013, 07:00 »
Years ago from Giebelstadt...
Attached 2008 version.
First one was 2006.
