Author Topic: Impeller failure after blockage  (Read 3333 times)
Petef
« on: October 19 2022, 10:16 »
I'm in a Facebook sailing group and this was posted so thought I would share.
Basically his engine raw water inlet got blocked by some plastic. After removing the blockage, his engine was still over heating. An initial visual inspection of his impeller looked ok. But! see pic.
Re: Impeller failure after blockage
« Reply #1 on: October 19 2022, 10:34 »
On my 40 cc I have had a water flow switch in the raw water supply upstream of the heat exchanger . Any interuption in the flow brings on an alarm . In the past many years it has detected several disruptions including my failure to open the seacock. Cost about £12 from I think RS componants and has proved its worth . Geoff
« Reply #2 on: October 19 2022, 17:43 »
I had an impeller let go like that years ago.
« Reply #3 on: October 20 2022, 01:55 »
Impellors will lose their blades after water flow stops for even a few minutes or less. Make sure you take off the front of the heat exchanger and remove the failed parts that could block some of the cooling tubes.
Markus
« Reply #4 on: October 20 2022, 17:35 »
I've got a pretty bulletproof system that's even cheaper than that: when ever I close the engine seacock, I put the engine key hanging from the seacock handle...  ;D
Petef
« Reply #5 on: October 25 2022, 15:00 »
Quote
Great idea but don't have a key, lol I just press a button
PEA-JAY
  • Boat Model: B-Cruiser 39
« Reply #6 on: October 25 2022, 22:45 »
You have an engine main switch though, with a detachable L shaped knob 😉
Petef
« Reply #7 on: November 01 2022, 09:51 »
  True, but sometimes the rear admiral does those. Guess I can put a label over it lol
