Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
Bavarian 36
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bavarian 36 (Read 2080 times)
David Gray
Cadet
Boat Model: Bavaria 36
Boat Year: 2003
Bavarian 36
on:
October 13 2022, 18:12 »
Hello, I would like to know what size of sail drive is on my recently purchased Bavaria 36 2 cabin with Volvo MD2030 with 2 blades prop with ambassador rope cutter, so I can purchase the correct size of anode prior to lift out, thanks David
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Re: Bavarian 36
Reply #1 on:
October 13 2022, 19:14 »
It's written on the type label, which you can find on the top of the saildrive (the gearbox).
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
Old Salt
Boat Model: B33
Boat Year: 2015
Re: Bavarian 36
Reply #2 on:
October 13 2022, 21:37 »
You will need a modified anode with a cutout to make space for the stripper. Available from Ambassador. If the drive is original it will be a 120 - easy to identify because it is one piece
Logged
David Gray
Cadet
Boat Year: 2003
Re: Bavarian 36
Reply #3 on:
October 22 2022, 15:14 »
Hi Thanks for the replies, after a bit of research not is it only the slot that is different but I believe that the side wall is machined down to make it thinner as I have seen some posts that say they cannot reverse, they are twice price so that may be the reason
Logged
Old Salt
Boat Model: B33
Boat Year: 2015
Re: Bavarian 36
Reply #4 on:
October 22 2022, 16:26 »
Yes, the recess is also machined out for clearance of the rotating cutter. Not sure what you mean by not being able to reverse as the shaft does not move backwards and forwards - just rotates in the opposite direction. This is unaffected by the cutter.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
Bavarian 36
