Author Topic: Bilge Liner Cracks  (Read 3123 times)
Sunharvester
  • Boat Model: Vision 46
  • Boat Year: 2016
Bilge Liner Cracks
« on: September 02 2022, 21:24 »
2016 Vision
Where do I even start with something like this?
No groundings. Hardly used boat this season except for local day sails. This is all just aft of the aft keel bolt.
Could this have been caused by residual bilge water freezing over the winter?  Allthough I'm pretty sure it wasnt there this spring.
How could this happen other than a keel strike?
Boat was on hard last winter
Re: Bilge Liner Cracks
« Reply #1 on: September 03 2022, 09:12 »
Looks to me like either a grounding or it's been dropped onto its keel.  Behind the aft keel bolt is usually caused by hitting something at 5kts +
« Reply #2 on: September 03 2022, 10:11 »
Where you there when the yard lifted/launched/moved it? Looks quite severe, not just some cosmetic crack. Definitely looks like impact to me. So if you didn't hit anything, the other likely explanation is the yard dropped it on the keel and "forgot" to tell you.
Porquerolles
  • Boat Model: Bavaria 42 Vision
  • Boat Year: 2019
« Reply #3 on: September 06 2022, 17:06 »
Les fissures sont effectivement assez impressionnantes.
Cela me semble en revanche, un peu trop "régulier", trop linéaire, pour être qu'elles soient liées à un choc, ou à un talonnage.
Je suis curieux de connaitre l'origine de ces craquements ?
« Reply #4 on: September 06 2022, 19:35 »
Il me semble que la quille a été soulevée par le l'impact et la commotion cérébrale d'être tombé, provoquant la remontée du gelcoat de surface créant les fissures, mais lorsque la quille est revenue après l'impact, le gelcoat est resté "soulevé" créant les fissures que nous voyons ..... (avec l'aide de ' Google'...)      ......Bill.
fjoe
  • Boat Model: 30 cruiser
« Reply #5 on: September 06 2022, 20:34 »
It doesn't help you anymore.
I payed a professional to check the used boat we finally bought. Return of this invest within several hours and beyond.
My recommendation if you are willing to pay tens of thousand USD, EUR or whatever: Pay additionally about 2.5% for an real expert.
« Reply #6 on: September 07 2022, 12:41 »
Hasn't he already bought the boat??
Porquerolles
  • Boat Year: 2019
« Reply #7 on: September 07 2022, 19:59 »
Cela ne peut pas être du au gel. Pas à ces endroits-là.
Les Bavaria Vision sont quand même des bateaux solides (enfin j'espère nous en avons un !! ).
J'ai vraiment hâte de connaitre l'explication sur l'origine de ces fissures.
Krumelur
« Reply #8 on: September 08 2022, 12:11 »
I'm really curious to learn what the boatyard has to say about this. Looks pretty severe to me :-(
marioxp
« Reply #9 on: September 08 2022, 15:08 »
Evo, da se i ja uklučim u raspravu na materinjem jeziku. Razumijem engleski, nije mi lako pisati na engleskom pa šta bih se mučio kada ionako postoji google translate.
Slažem se da ove pukotine su mogle nastati jedino od fizičke sile.
« Reply #10 on: September 09 2022, 10:20 »
I agree, it does look very much like damage caused by a violent upward force...The Boatyard has a few difficult questions to answer.......Bill.
