Author Topic: Saildrive type  (Read 1910 times)
ICENI
Saildrive type
« on: May 15 2022, 13:16 »
Hi Forum,
I am on board right now and about to do some jobs.   I have one down to check the particulars of the saildrive.   I have found the plates for the Engine detail and the gearbox but I don't know the type of the saildrive.   Previously I have filled with normal Volvo mineral oil but someone said ATF?
I do not think ATF is cofrrect and I should use 10/40 mineral oil.
Can anyone inform me the model saildrive for my engine please.   It is a 2020 B1 Engine.
Any help would be greatly appreciated please>
kavok
  • Boat Model: 40 Cruiser
Re: Saildrive type
« Reply #1 on: May 15 2022, 14:08 »
120 or 130
Both use same engine oil.
Keweetoo
  • Boat Model: Bavaria 35E
Re: Saildrive type
« Reply #2 on: May 15 2022, 16:14 »
Not all saildrives use engine oil. The 120 S-E (which we have) uses synthethic gear oil API 75W-90. Chart attached
Re: Saildrive type
« Reply #3 on: May 15 2022, 18:35 »
Like Kewee says, the 120S-E is using API GL-5 hypoid gear oil (not ATF). All others you'll find in sailboats use engine oil of the same spec as the engine.
ICENI
Re: Saildrive type
« Reply #4 on: May 16 2022, 11:02 »
Many thanks to you all.
