Author Topic: Cabin lighting  (Read 5430 times)
Scallywag too
Cabin lighting
« on: July 18 2013, 16:10 »
The the three lights in my front cabin have all stopped working at the same time on my bavaria 40 I've not had a chance to check anything yet I'm heading back to the boat at the weekendend is there something simple I could check after the bulbs
Anthony
Re: Cabin lighting
« Reply #1 on: July 19 2013, 05:18 »
On my 2001 Bavaria 40 found one of the lights flickering even when switched off! Removed it and found fresh water ( no salty taste) had got behind it. Still mystified about source.
My advice to you would be to replace the incandescent bulbs with LED discs... much brighter and much lower power consumption.
Re: Cabin lighting
« Reply #2 on: July 19 2013, 10:22 »
I had water in my light in fore cabin found it to be "U" bolts not sealed good enough, but the u bolt in the centre had the wires for the lights go in between the 2 legs of that ubolt.
Scallywag too
Re: Cabin lighting
« Reply #3 on: July 20 2013, 01:31 »
We're at the boat tonight I gave them a bang and one came on ill check the connections tommorow
Thanks for the help
                                John
MIA
Re: Cabin lighting
« Reply #4 on: July 26 2013, 13:55 »
John
The cables on mine have spade connectors see if they have came loose or the feed to the first light has parted, if you don't get them to work I'll test it when I get back home in 4 weeks
Stevie
Scallywag too
Re: Cabin lighting
« Reply #5 on: July 30 2013, 23:12 »
Thanks I got them working ,thanks again for a loan of your wetsuits I rinsed and dried them just let me know when your back
