Author Topic: B36, 2004 - Resistance of holding tank level sensor  (Read 2215 times)
« on: October 21 2021, 12:04 »
Anybody knows what approximately should be the sensor resistance?
My sensor was never connected and I thought of building a circuit to get the level reading.
Connecting an ohmmeter to the exposed wire ends I get several hundreds of kilo-ohms  and I suspect part of it is due to wires corrosion.
Reiner
  • Boat Model: Bavaria 36 cruiser
Re: B36, 2004 - Resistance of holding tank level sensor
« Reply #1 on: October 25 2021, 17:01 »
what i know, its only a full level indicator. It shown on the panel with the red led.
You can not measure any resistance unless there is no liquid contact.
paulemeier1
« Reply #2 on: October 25 2021, 19:57 »
liquid closes the circuit. No liquid no circuit. on of switch like. sorry bad english
the liquid opens or close the circuit
« Reply #3 on: October 28 2021, 13:17 »
Thanks. If this is the case I will continue using my good old "level meter"  - tapping along the sides of the tank and listening what sound it makes
« Reply #4 on: October 28 2021, 13:20 »
I shine a little LED torch through the side of the tank - you can see a change as you move above and below the liquid level.
