Author Topic: Leaking diesel pump on D2 55  (Read 2545 times)
elias
« on: October 18 2021, 08:49 »
Hi to all ,
As you can see in the video , I think that something inside there is reached it’s lifespan . Would you do 5 hours of motoring with that issue ? Or I am risking something great ?
tckearney
  • Boat Model: B42
Re: Leaking diesel pump on D2 55
« Reply #1 on: October 18 2021, 09:26 »
I think your risking a fire
« Reply #2 on: October 18 2021, 13:12 »
Rather than a serious fault, it looks more like the gland/seal between the injector pipe end and the pump is giving up the unequal struggle against the extremely high pressure in the pipe and simple needs to be removed, resealed and bled.......I also agree with 'tckearney' and wouldn't run it like that, certainly not for 5 hours.
elias
« Reply #3 on: October 18 2021, 17:23 »
How tricky …over 1000rpm not even a drop … only in idle it sprays out …
« Reply #4 on: October 18 2021, 21:41 »
I still think it's only the gland/seal ....and fortunately nothing really expensive..
elias
« Reply #5 on: October 20 2021, 19:54 »
It ran 5hours 1800rpm , not a drop . Strange . Either way i ll have it taken out and replace all the seals .
