Author Topic: portlights B39Cr 2005  (Read 2332 times)
mowa
  • Boat Model: B39 Cr
« on: September 21 2021, 12:07 »
I have some water ingress in the fixed upper deck portlights, where the arrow signals. This is the place where the water remains more time. Surelly it is the rubber joint that is beginning to deteriorate. It is easy to change? Where to find this part? I am not sure that it is from Lewmar.
Klausen
  • Boat Model: Bavaria 37 cr
Re: portlights B39Cr 2005
« Reply #1 on: September 21 2021, 19:54 »
I sealed mine a few months ago with butyl tape, it was'nt the rubber!
mowa
« Reply #2 on: September 22 2021, 09:12 »
ok, many thanks, so you disassembled the portlights unscrewing the hexagonal bolts, cleaned the old sealant an installed the new butyl tape. Correct?
Klausen
« Reply #3 on: September 22 2021, 13:52 »
Yes and at the joints of the alloy frame I filled some Sika in.
mowa
« Reply #4 on: September 22 2021, 17:00 »
One last question. Which butyl tape size did you use?
Klausen
« Reply #5 on: September 22 2021, 17:46 »
I'm not really sure, but I think it was the round type of 5 or 6mm . Two lines in parallel.
PEA-JAY
  • Boat Model: B-Cruiser 39
« Reply #6 on: September 23 2021, 22:30 »
Might I ask, do you still have the butyl tape packaging or know the brand name?
Klausen
« Reply #7 on: September 24 2021, 13:25 »
I ordered the butyl from " www.fugendichtband24.de". It was the 5mm "Rundschnur"
« Reply #8 on: September 25 2021, 17:08 »
Butyl tape is butyl tape, the differences are minor (some is more goopy though). The size doesn't matter so much either as it's very malleable - you can stretch it thinner or stick two strips together to make it thicker.
