Author Topic: Fridge packed in  (Read 3406 times)
diverphil
  • Boat Model: 33 cruiser
Fridge packed in
« on: July 04 2021, 13:08 »
Help. Our fridge just stopped working. I've checked the 12v supply and its ok. Have put an led to test between small + and D terminals as per danfos diagnostic site but I didn't get any blink code.
Also put a link across c & t terminals to take the thermostat out of the system, should run permanently  to do the test. But nothing runs. Any ideas?
Re: Fridge packed in
« Reply #1 on: July 04 2021, 15:18 »
No diagnostic LED and no action in presence of good power supply means the fridge controller has died.
If your compressor is a Danfoss/Secop (most of the rebadged boat friges from Weco, Frigoboat, Penguin, etc. are), then this is the unit you need: https://www.ebay.co.uk/itm/273083414314
diverphil
« Reply #2 on: July 04 2021, 19:09 »
unit is weaco, compressor is danfos, will get hold of one, hoping it fixes it as we are on boat in 2 weeks, but cant get down before.
thanks
phil
« Reply #3 on: July 06 2021, 03:32 »
Phil, if your boat is still at Conwy Marina, there is a firm of refrigeration engineers, J.D. Refrigeration based at Conwy Road, Mochdre if your system needs re-gassing.
diverphil
« Reply #4 on: July 07 2021, 14:04 »
Boat is at pwlhelli for this year. Are there any fridge engineers down there.(that would go to a boat if req)
« Reply #5 on: July 22 2021, 14:24 »
Only just seen this . It is worth taking a separate supply via croc clips direct from  the battery if a fridge fails to start . On my fridge the electronic low volt disconnect was fast enough to not show on a voltmeter , the multiconnector in the electrics cupboard was corroded. Geoff
diverphil
« Reply #6 on: July 23 2021, 10:40 »
Tried all the tests etc. Put a new control on last Sunday all seems to be working again.
Thanks for the advice
Phil.
